2003 Honda cr85r
So I’ve got this bike and I need to know if it needs to be timed on on the flywheel to run right ? Or is it already setup
Timing is already set up, why are you asking for is something not working as it should
My bike keeps fouling plugs and I just wondered if that had anything to do with it, and would the stator have anything to do with that ?
Fouling plugs can be a number of things,
Right hand side crank seal needs replacing if oil level keeps dropping
Reeds are worn
Oil in fuel has a high flash point
Compression is low
Carburettor jetting is off
Also have a read here
https://thumpertalk.com/forums/topic/347305-is-your-two-stroke-running-rich-read-here/
9 hours ago, Nicolai said:
I will check some for some of these things
If you want to fix it properly, you should not only check some but rather ALL of those things.
  • Like 2
