Fcr cracked slide
Hi
I’m not sure if this has been posted before but I bought a fcr mx and I am running stock header, slip on, 3x3 I have 160main jet, 45 pilot and EMN needle 3rd down I’m at sea level, when the throttle is fully open runs fine when I hold the throttle slightly open steadily the bike splutters and jumps, I turned the fuel screw all the way in and the bike runs better so down sized the pilot to a 40 but still has screw turned in all the way and idles better, if I take the air box cover off runs a bit better any thoughts?
Also I noticed that the slide on the engine side has a crack in it, could this have anything to do with it?
TIA
Replace the cracked vacuum release plate. If it breaks more, the engine will ingest it and you will have serious problems. And yes, a damaged part in the carb can cause running issues/
