2006 KX250 CAP BASE VALVE CRACKED
So I have a shop currently rebuilding my front forks. They called to say the plastic part under the fork cap was cracked. Looking at new ones, they run around $300. Is this something that for sure needs to be fixed? I imagine so...but thought I'd check. Anyone got one laying around from a bad fork they want to sell? I looked on ebay but didn't have much luck.
Looks like after a little more research it is more commonly known as the free piston. Doesn't seem like you can buy just the plastic part, but need to buy the whole assembly. Also seems to be no aftermarket parts for this year bike. If someone knows of one that would be awesome.
Buy a full set of used forks (ideally in better condition than your present set). That’s what I’ve done, since my original set’s upper tubes were trash. I’ve made a prefect set, from two sets.
I had that thought, but I can't even find a set of used 06/07 forks on ebay.
Look up Zeta, SDI, Race Tech KYB free piston.
Be sure to get the one for your year. If the other one is not cracked, consider getting a pair.
Don't ever take your forks there again. JEEZ! Companies have been selling those for around a decade or so.
Motox367, is that your pic?
Do you have more pictures? I could see myself buying a pair from some company in the future. Mine were not cracked at last service, but I know I am somewhat lucky on it. I have multiple sets of those forks, too.
If they are yours (or you put them in for someone else's forks you were working on, how did you think they looked?
Thanks!
Thanks!
I put them in few sets of forks their really nice and aluminum.  Nice and open instead of closed like oem plastic one. Well worth the 70$ never worry about them again
2 minutes ago, KDXGarage said:
Thanks! I assume they are made in China. Are they?
Well ofcourse ? sweet tho i must say
1 minute ago, KDXGarage said:
Yeah, that does look good!
I was breaking them 07-09 didn't know about aftermarket ones or even if were available then cause wasn't on internet at that time. Had to order them from Japan 250 a peice.  Thought i was only one breaking them at the time lol . Finally learned to just drill 2 holes and never broke one again.
Thanks for letting me know.
No problem ??
I have emailed both Zeta and SDI. I cannot find them for the 2006 KX250. They all show KX 450F. They both responded that they no longer make them for the KX250 and they are not compatible with the 450F one. I also emailed race tech but they do not have one that shows it matches a KX 250 either. Still waiting to hear back from them. I spent a good part of the day exploring options and looking for an aftermarket or anything that would fit, and I could not find one. I found the entire assembly for $225 at partzilla, so for now that is what I have ordered to keep things moving, but will gladly return it if someone knows of an aftermarket that will fit.
Drill 1/8" hole top and bottom wont crack again
