DRZ 400S Stator Noise - fixed. :)
Posted (edited)
Hi all, I thought I should share my experiences with the problem I had with my 2000 vintage DRZ400.  It is very low mileage at 7000 miles but has always had a distinct knock from the stator area.  I thought it was a worn big end bearing but the noise was the same under load and disappeared at a constant throttle setting so I just lived with it for ages (18 months).
I eventually decided that the loctite fix for the stator was a good idea so set about removing the stator cover and all looked in order, although the 6 stator allen bolts were only snug...not very tight.  I loosened one and noticed as I was working that the stator rotates a bit even with the bolts in place.  They sit in large recesses and this allows the stator to move (rotate)a little backwards and forwards.  I was a little bemused by this but proceeded to apply loctite and fasten everything back together.  The stator bolts were not central in the recesses but I could not see what difference it would make so I put it all back together...
On starting I was delighted to discover that the engine was as quiet as a quiet thing and all the knocking has gone.  I can only assume that the stator was moving about a bit and causing the terrible noise.
If anyone has any idea why the stator bolts sit in a large recess I would be interested to hear...  maybe I have done something wrong and it should move a bit but all seems well at the moment and it sounds like I now have a new engine!
PS..  I have just replaced the bash plate and the engine is noisy again!   My "fix" was not as conclusive as I thought and the bash plate seems to amplify the engine noise quite a lot!!!  The stator is definitely quieter but the bash plate seems to be the main culprit!
Edited by DRZ4000
  • Haha 1
My next oil change I'll be coating my skid with bedliner- may not be significant but should be a tad quieter.
Many thanks to Scott... I had some left over sound deadening material so I glued it to the inside of the bash plate and Eureka... lovely quiet engine again.  Works and absolute treat!!!
This happened to me.last year, rear skid plate bolt (in front of shock linkage)  fell out while riding. Bike started making a horrible racket, thought something went in the motor! So while letting it idle and putting my ear to the motor in various spots I noticed the skid plate vibrating...I grabbed it and the bike went quiet as a church mouse again. Took a stick and shoved it between the plate and frame till I got home that day
