Dealer inside info. 300XC TPI
Walked in to the dealership today to pick up a sprocket. They changed them and now have holes drilled to allow the sprocket to brake if/when there is a transmission problem per parts guy.
Then he told me that 2020 will yield an XC in both a 250 and 300. As of right now he says there will be no carb’d version after this year. The 150 will be carb’d along with the SX250. There is also more maps coming out. Right now he says there is a sport version. Later a track map will be available.
SmokeX
  • Helpful 1
  • Haha 2
I would he amazed if that sprocket ever broke
  • Like 14
Me too. And I just replaced it. Seems I have one just like it on my 19.
Have you
 herd of the xc tpi as of yet.
Posted (edited)
As Tokyo offroad suggests, clean out with a tap prior to installing the new sproket (and new bolt and spring washer) or it will likely reach the torque spec prior to getting tight enough on the spring washer. I didn't do this when I changed mine and used a pain pen to mark the bolt and washer so I could see if it moved and it did about half a turn. I'm going to back it back out and clean the threads this time.
Edited by Dirt Rider 12345
  • Like 2
it's  pretty hard to imagine that thing breaking, they might also think it will break if a broken chain wedges in between the CS and the slave guard; not very likely me thinks.
  • Like 3
Looks like factory bikes use the holes to safety wire it to the nut
  • Like 3
Yep. Saw that one. Thank you.
Also new about that in shooting sports when using lock tight on scope rings.  Same thing can happen and ya loose your zero. ?. There goes the match.
I like that guy. Also that Australian enduro cross training guy are prolly one of my favorites to watch.
Btw- I ended up lining the yellow factory paint marks pretty good. I’ll keep an eye out for it. Also used lock tight after taking a pretty big chunk off the factory stuff.
Posted (edited)
2 hours ago, SmokeX said:
I think you parts guy is stupid, you never want a cs sprocket to break That would be catastrophic to someones life, not to mention possible busted cases. Those are lighening holes, common in after market.
Edited by Spud786
  • Like 13
  • Haha 1
The oem spring washer will spin no matter, even the dirt tricks will move, and its 3 times the strength of the oem.
  • Like 2
LoooL.:-)
Ok. Cool. I never gave it a second thought to the factory yellow marks lining up until I put it back together. Your saying the washer will move or spin but doesnt effect anything. ?
The main thing about the spring washer, is allowing outward flex of the sprocket, this will aggravate wallowing of your counter shaft splines. If it spins alittle , it doesn't really matter. Dirtricks has a lot stronger spring washer, to keep more pressure on it.
  • Helpful 1
Ok. Thanks for that. I’m still learning a great deal guys, although what I have learned so far seems quit enormous.
If the guy thinks the holes are do the sprocket breaks, hes likely making up the other stuff too.
  • Like 5
After he said the holes are so the sprocket is sacrificial his credibility dropped to near zero.  It may be to allow safety wire but that is extra work just for factory teams so I am guessing it is just to reduce weight.
Yeah,  like everyone is saying,  break away sprocket is total BS.  LOL. Was this guy a former used car salesman?
  • Like 3
LooooL. Sounds like it. I placed a call to the dealership after posting. I hit 3 for sales hoping to get someone else but he answered. So I just asked him if he had dirt tricks washer in stock. I’ll call again tomorrow and talk to the manager. I’ll also comment on the sprocket. .
 he still might be right. The fact is, if one dealer knows than there are more as well. He said it came from KTM. I have a ride tomorrow too. But I’ll work it in.
4 hours ago, SmokeX said:
Have you heard of the xc tpi as of yet.
There have been rumors for the past year or more that KTM would go 'TPI only' on 250 / 300 XC models at some point.
fwiw,The superceded ktm washer is the same thickness as the dirt tricks. Both thicker than the old ktm part.  Ordered both and measured. Same.  Most people that have had problems have the curved washer on backward IMO.  Like the idea of safety wiring it though. The piece it sits into is made so it limits the clamp on the collar and oring, so yes the belville washer could move. My crf is the same way but smaller bolt and lighter washer. It's never got loose either, with anti seize or grease and no loctite.  It's a better design than the circlips ktm used to use on the 2 strokes.
Well if it's true then I won't be buying a new bike next year. I wanna give KTM time to iron out all the kinks in the TPI system. I feel like it got rushed out of the door because of the new emission laws in Europe. Give it a couple years to refine the tech and then I'll consider one. Or maybe I'll pick up a leftover 2019 next year if I can find one
  • Like 3
