Looking for help ? Plastics and graphics
Wondering if anyone can help me find or tell me where i can get standard plastics/graphics for 2008 CRF450r
Doing ground up restoration on my bike .
Would like it to look factory like the red bike
Located in UK
Plus 1. I put polisport and factoryeffex on mine. The plastics were great. The effex’s quality is awesome but slightly smaller in size compared to factory.
Located in UK
So that's an 08'!  Hope you do know that they came out with a black edition with ghost flames from the factory.  I think there were only like 800 bikes released in black.  I have one.  Very sexy.  Currently mine is getting a full rebuild on the engine with 208 hrs.  It will be a new bike when done.  Adding in a Stage II hotcam as well after I found .001 play in the cam bearing.  That's where it all started at checking the valves... While waiting on the new cam I decided to change piston and rings and then down to the connecting arm and found play on axis.  So now I've got the case split and a new bottom end kit on the way.   It always starts small and harmless doesn't it?  Then you are into a full bore rebuild.
I did know that there was the special edition. Sorry, I don't like how it looks...
Hi man , yes nice looking bike , i know about the special edition in black was going for factory red option , also done my bottom end rebuild today , wiseco bottom end kit
David, your clutch basket looks like it has some notching and two plates are missing ears??
Yes well spotted notching isnt that bad Tbh , and for the plates thats my fault broke them trying to hold for re torquing centre nut on basket
Try using a strap wrench or putting a copper penny in between the gears on the rear of the clutch basket to hold it.
Awesome,  Mine is ready to button up.
Doing a bottom end is a therapeutic experience.   Mine is ready to put the case halves together.  I took that day off from the bottom yesterday and honed the cyl and lapped the stainless valves.  I put in a HotRods crank.  Still shopping for a piston but will likely go with OEM.
