2012 rmz250 transmission swap
Hi guys, I have a 2012 rmz250 that I’ve owned since new. Ever since I got the bike it’s always had a rubber transmission. I’ve done the detent spring, upgraded clutch springs, ext. only to have the false neutrals come back. I seen someweres someone saying to swap the transmission out with a 2013 transmission. From what I have read they will swap right out with each other but u have to change the counter shaft bearing out bc the 2013 shaft is bigger that the 12. My question is, is the countershaft bearing the only thing I would have to change out to make the 13 transmission work, and by transmission I mean the gear stacks, shift forks,shift drum,shift start and the shift mechanism on the clutch side. Thanks for the help
Yes just the counter shaft bearing.then the complete 2013 transmission as you stated.
