LEAK DOWN Vs. COMP. TEST
Posted (edited)
Am I doing something wrong? First a I did a Comp Test , whiched failed around 45-50 PSI but the leak down passed with flying colors. Does a leak down test disqualify a compression test ?
Thanks
2005 DRZ400
Edited by Bigmacdirt
the DRZ S and SM has an auto decompressor on the cam to allow easier starting this would cause a bad comp test
Did you hold the throttle wide open during comp test? And was the engine warm?
Thottle open and Choke on , Engine runs very poorly to pretty much doesn't run
Interesting. No idea, besides your compression tester is just faulty/leaking pressure around the fitting etc.
No Problem , thanks for trying to help , I tried 2 different Gauges and hoses/adapters both same results , Think It has something to do with this decompressor , I slightly saw something in the repair manual about it ,
Posted (edited)
Did you use the same hose on both test ? You need to remove the valve for the leak down test , otherwise You’re not pushing air into the engine and your gage will show no leak , ask me how i know.
Edited by habs
All DRZ's have an auto release on the stock ex cam. With this decompression working the factory manual states compression should be around 130 psi.
Compression test is a good quick health check.
Leak down test goes further in helping you diagnose where you are loosing compression.
Thanks
2005 DRZ400
With stock cams compression test results have  compared against specs accounting for the dcomp device.  Did you use jumper cables, jump pack or other power source while cranking the bike? Throttle full open?
After the low test numbers did you try again having squirted some oil in the cylinder?
You did not say what the leak down test numbers were that you felt passed with "flying colors"...assuming leakage was 15% or less or "passed with flying colors"
In answer to you question, NO ,if both tests were down correctly with functioning tools I can see no way to get 30-40psi on a compression test and 85% or better on a leak down test
Posted (edited)
No Jumper or Squirt of oil ( how much oil)
I am 110% sure that I am using the right hoses , valved for comp test and no valve for leak down
Using a OTC leak down gauge , set 90 psi going in , second gauge is pounds held in Chamber which reads 86 psi
Compression is a dynamic test (moving parts) and leak-down is static. If only a a portion of the cylinder wall was badly scored you may indeed have a low compression reading and if the piston/rings happened to be located on a "good" zone of the cylinder while running a leak-down it could result in a good test.
But as most others have said, check to make sure valves are fully closed first.
