Suzuki Jr 50 Oil
Posted (edited)
Having a manual for your bike is an important tool. Here's a screenshot from one online. Dated 2005. Recommends multi grade 10w-40. I would assume use wet clutch engine oil. Maybe some else can verify20190420_093917.thumb.jpg.3c58cd22dee579a189203bf8d97d2f82.jpgScreenshot_20190420-093026_Drive.thumb.jpg.65fd084dd8964993732d9c9ae05e2c23.jpg
Edited by bikeguy17
I'm dumb
We had a jr50 and would use motorcycle 10w40 in it. I suspect the red fluid might be bel-ray 80w or something there are some 2 stroke bottom end oils that are red but you should be fine with a 10w40 thats what we always used with no problems.
Thanks heaps.
I am also worried about the oil injection pump and if it is still working. Is there any way to test it first?
Thanks for that screenshot.
Is there anyway to see if the oil injection pump on the bike is still working? It is just so old and I'm not sure?
Posted (edited)
I'm sure there are ways to check for flow but
one way to play it safe is to fill the oil injection reservoir
and, also premix your gas to say 40:1  (in the event that it's not functional)
After a tankful of gas has been used up, measure the oil required to refill the oil reservoir
and calculate with the fuel tank's capacity if the consumption is in the 30:1 to 50:1 range.
(divide the amount of fuel used by the oil required to refill)
In the event the system is functional, the extra oil won't hurt and at most might foul a plug.
(use a low flash point premix)
Edited by mlatour
  • Like 2
Thanks I'll do that I'd say.
Hi I have another post on some more problems you might be able to help me with. ?
