Does anyone have the ohm readings for a stator on a 2006 Yz450f written down! I would greatly appreciate that! I just got the zipty modded carb back, new gytr weighted flywheel, timing chain, valves shimmed, billet got start nit, and a lot of other goodies put on the bike. Before it would run with a roll start as carb was clogged? But once started as long as it was kept revving it would pull you off the seat. Now the spark plug has no spark and I can’t for the life of me find the ohm readings for a static test on the stator. Which wires ohm together and what should they read? Please help
Had Yamaha dealership test them for me. Ignition coil is half dead and stator is full dead. Now the hunt for cheap replacements. Are all coils made equal for these bikes? Is a 2006 anniversary edition different? Is a 2009 better? Are all coils and statues made equal from 06-09?
