M A T
Kouba links and spring rates?
A long time ago I put Kouba links on a DR350 and from what I remember it reduced the spring rate (the links resulted in more leverage on the spring).  I can't remember if I added a new spring or just more preload.  I assume this is the case with the 690/701 too?  I also think the links resulted in a more linear rate (less progressive) which actually worked out well with the DR. Not sure how these bikes are sprung in the first place but I'm 145#.
I add a Kouba Link to my 2019 690 R and found it noticeably softened the rear.  Not a huge change but nice.  I'm 6'1" 201 lbs (Expert) and the link really helps me reach the ground.  I'm fine with a tall light (230lbs) bike in the dirt but at +300 lbs the 690 can get to be a bit tall (stock) if the terrain turns technical like the Devils Racetrack in the San Rafael Swell (UT).
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
