How do I remove the stator assembly off of my 01 cr125r?
I've been having a problem with my 01 cr 125r, where it runs but doesn't run right, what I mean by that is it sputters and backfires and doesn't rev out every time. I had a shop try to fix it they went through everything but the electrical, I was wondering how to remove the stator assembly off of my bike, do I need to split the cases to get the not loose off of the main coil area? Or can I remove it without splitting cases? Thanks for the help.
Take the left cover off( Flywheel side) you will need a puller to take the flywheel off(see pictures) then is only two bolts to remover.
It will look similar to this.
