smez
Pacific crest cone look stock pipes
This stock yz250 pipe has been through the workshop at pacific crest pipe repair for $140......apparently...
  • Like 5
1 hour ago, Ltlhondarida125 said:
How beat up can a pipe be to make it not worth sending in?
Look at the web page. Pipe that has been looked like it was ran over comes back looking great.
Posted (edited)
Pipes have "memory" when you
fix them. Best to have the bike
to make them fit properly. Using an
oxy acetyl torch, and air pressure
around 80, and up to 120 psi for
the tough bends, seems to work
well. Biggest problem is getting the
pipe clean inside.
Had one "blow out" a rubber plug
from the silencer end a couple
weeks ago when something ignited
inside the pipe, which is what it is
supposed to do, instead of blowing
the seams out of the pipe.
Probably a patch of
carbon that had some fuel residue
in it. Launched the pipe out of a
vice, and across the room.
That was after a varsol soak, soap
and water, and frayed aircraft cable
in a drill to remove carbon deposits
BOOM !        Be careful
Edited by yamaha7654
  • Helpful 1
pipe clean inside.
Probably a patch of
BOOM !        Be careful
I personally think that a 100psi is extremely  dangerous (100psi x area get it? Air is compressible ).  I think that way lower pressions would be sufficient and safer. My 0.02
2 hours ago, Ltlhondarida125 said:
Is the cone weld pipe stronger then a regular oem or procircut pipe?
Looks only
On 7/22/2019 at 10:38 PM, mikedeezxxx said:
That pipe looks like it has holes all through the welds. Or maybe it’s my phone. Idk
If you zoom my in, it looks like shit!
No it does look like crap the welds are not very uniform if you look closely you can even see some gaps in the welds where they missed a spot.
