Tuning advice/reviews
I have a 17 350sxf that I've been thinking about getting something done to it to wake it up a little. What's the difference between getting my ecu remapped and something like a vortex and is it a noticeable difference because honestly I'm not sure I can tell a significant difference between map 1 and 2 ... sometimes I think map 2 feels a little snappier but maybe I'm just assuming it is.....
The remapping gives a small boost ,I got 1hp more across the board from a get ECU ,this was on the 250 ,the engines do respond similar
How much did that run and do you feel it was worth it??
The GET is worth it just for the adjustable traction control and the ability to create a map from you smart phone at the track!
Get you head ported, and re-map to match.
The stock mapping is already near the ignition and fueling limit for the stock head, so you will get only a 3-5% increase in power above 8k rpms if you get a Vortex or Athena by itself. Put them together and it will be a big change.
It was £350 I think , and as mentioned you can alter it from your phone , in hp normally 1hp costs around 1k ,do it's great value for money
