Other then the streamlining of hardware...what is the advantage of or any disadvantage(s) of deleting / removing the stock thermostat and replacing with an SD Powerhouse kit? Thanks
"is designed to improve coolant flow, simplify and improve engine venting system"     It removes the thermostat and air injection solenoid purge valve so that emissions systems can be removed.
disadvantage- no thermostat.  Less efficient in burning supplied fuel while operating at low temperature. During cool weather may not maintain operating temperature..  in a racing world this would be fine as the bike is always putting out power and making heat.
  • Like 2
  • Helpful 2
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
