Anyone have success with a hitch rack for their XR? My tongue weight says 400lbs. The XR is 350(ish)lbs, and racks seem to be around 50-80lbs. Any suggestions on rack type, what’s the lightest rack there is, or is it just going to be too much weight. (It’s on a 2012 Mazda CX-9)
i have a hitch carrier called the ‘switch hauler’ from a company called ‘all jacked up’ in cali...its for dirtbikes as it picks the bike up under the skid plate, which makes it handy for service work. i have an ‘03 4runner that i use to haul the bikes around (450X and XRR)- havent had any issues yet in 3yrs. the 4runner is a body-on-frame while your mazda is a unibody.
i would say your challenge is not going to be with which carrier or hauler you use, but whether your CX9 can safely handle 350-400lbs tongue weight
The aluminum racks made by Black Widow are very light and affordable. I have three single carriers from them, and one double carrier. That's almost exclusively how I move my bikes around.
But I also am aware of the limitations of the vehicle that I am driving. For example, I will not ever tow with the double carrier on my wife's Land Rover. The front end just gets to light.
On my Silverado 2500 HD, my rear end was sagging a bit. So this afternoon I am installing airbags.
I also have a class 6 hitch so I am never afraid of it breaking. You should remember that the weight on the receiver can double or triple when hitting a bump.
  • Like 2
I’ve used both of these with pretty good success the aluminum one is from harbor freight. Pretty light and cheap. The versahaul is much nicer but kind of a pain to load bike by myself. I’d recommend either of them
Edit : aluminum one is about 35 pounds. Versahaul is about 80
  • Like 2
I’ve towed a couple different enclosed trailers and it seems to be ok, but I’m not sure how close it got to the 400lb tongue weight. I really wasn’t sure if the manufacturers put a big cushion on there as I’d be getting really close to the Max tongue weight.
So it seems I’d have to go with an aluminum one so that I can keep it under 400lbs
I have a bike carrier and it works. But I am always scared that I lose my bike going through dips because it is shaking a lot.
I rather use a trailer *scared if not*
i can understand that, when i got mine i was concerned as well, but the one i have is pretty heavy duty and steel, i just take it easy when driving and check the nuts and tie downs and things have always stayed tight. im sure some of them, like a cheap aluminum chinese carrier w a loaded XRR would be a bad idea
Mine is made out of steel, but it still shakes a lot. I do not trust those carriers. Might be just me. I like my bike to much and do not want to loose it on the highway ;)
Mine is made out of steel, but it still shakes a lot. I do not trust those carriers. Might be just me. I like my bike to much and do not want to loose it on the highway default_wink.gif&key=56b691046144ecb2770ec5a9cfb5efddcddfe1189ff6d027541fea22773efed4
Eh I have drove a 100 miles to the track and back about 40 times now and my bike has never moved. I use ratchet straps and the only way that’s coming off is if I have a much bigger problem.
no problem, but understand there are a lot of hitch carriers out there- they are all not the same. mine doesnt move around too much because the bolt threads into the hauler itself which eliminates rattles and movement. if you buy a quality sturdy model you have no worries. there are videos of people testing/driving offroad with a bike on the hitch and it stays put. not having a trailer to deal w is pretty nice for my needs
my concern is more getting rear ended- ive added reflective caution stripes and going to get a license plate / brake light to aid visibilty
Where are you from
Be careful with those aluminum harbor freight ones. There are plenty of reports of them breaking where they go into the reciever. Aluminum does not have a terribly long fatigue life when you bend it like that.
the insert is steel on the harbor freight ones
  • Like 2
Yep. No issues with the latest version of HF carriers. I have had five XR's, none approached 350lbs. What the heck have you added to that thing? XR-L maybe?
Yes it’s an XR650l.....aka the pig. 349lbs.
Where are you from
I live in the Philadelphia are
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
