Devon Jacobs
Blinker turn signal trouble
So I Just got a brand new rear tire installed but today when I was riding my turn signals stopped working when iI push the switch for the left signal the right signal light comes on but doesn't blink and vice versa as well as my horn doesn't work and my brake light wont work either its just static.
I already checked all my fuses I am stumped
Its a 2018 Honda CRF250L RAlly
any advise or help would be greatly appreciated
I would start by checking everything on the rear most loom, (rear light, brake light etc.)  If nothing is working it could be as simple as a plug disconnected, what ever you do think simple, it's easy to over complicate things. Also you could ask the tyre fitter what he took off or disconnected if anything, contact me if you have any more questions.  Attached a wiring diagram for the 250L  (pre-Rally)  but shouldnt be too different.
Cheers Jeff
Just thought this diagram may be different to USA specs if your turn signals act as running lights
Edited by Tigger800xc
Hey man, i'm having the same issue on my 2019, did you ever a way to fix this?
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
