Erratic and Surging idle
so my 03 cr250 has been giving me headaches. it has a surging and almost erratic idle that also happens when you down shift or ride any less than 1/2 throttle. Went through almost every jet size and a few different kinds of reeds with no luck. please help
Test for air leaks,
don't ride it until you've confirmed the crankcase is sealing properly, count yourself lucky you haven't seized or damaged the engine yet.
6 hours ago, mlatour said:
Test for air leaks,
I know there is a small crack in the front of my case that was JB welded. i have a feeling it didn’t stick and that is where my air leak is. Definitely gonna get on the pressure test this afternoon. Thanks for the tip??
