Flywheel weight
I ran a stealhy 10 oz and a 13 oz at different times on my cr 250. You can also just run steel clutch plates to add weight and to reduce aluminum shavings in your oil. Get a tusk clutch kit for cr 250. It's all steel clutch plates and it's cheap.. and it works good. You can switch out your aluminum plates for steel from the tusk clutch kit and stash the fiber plates for later on.
