04 Ktm 450 exc sm swap
I did everything by the manual said I just switch to sm rims and put axel sliders an took the axel puller out so idk if I did something wrong or they put wheel bearings in wrong I never did this  before an dnt kno much about it  But thanks anyways and if anyway has any knowledge to help it be much appreciated thanks
The manual gives a procedure on how to install the front wheel to prevent binding. Did you install it exactly how the manual said? Before you torqued the pinch bolts, did you compress the fork to center the fork legs?
