Loose valves.
2002 yz250f.  I checked the valves the other day after some starting and running issues. The issues were hot starting and hanging idle .
EX,    27   22   spec is 17-22
IN.    20  12  17  spec is 10-15
Curious what caused the valves to loosen . Dont they usually tighten up ?
Carbon build up on face, or bent are the causes for the gaps to open up. Or they could have set wrong the previous time
And I've seen the shim get cocked over sideways on install, then when it drops into the pocket, the clearance opens up.  So I feel the to top of the shim/bucket for even placement in the pocket now.
