KTM Steering Damper oil rebuild
My KTM / Husaberg Steering Damper wouldn't turn past a couple of settings.  I took it apart trying to figure it out. I think maybe I had turned it past the stop somehow and that's why it won't work. So now that I want to put it back together, I don't know how much oil I need or the type of oil to use.  Help.
Its mounted on a 2013 KTM 300xc
used 5w fork oil, where do you usually have it set?  you can go thinner or thicker on the fluid to get it more in the middle of the range
You fill it to capacity.  Try to get all the air out.
