Rm125 identification
Hi, I was just wondering if anybody could help to determine what year my rm125 is. It seems as if it could be a bit of a mix and match.
The frame seems to indicate that it is from 1989 as the serial is rf14a-100310
The engine would match as the code is F114100290 which is from 1989 onwards
I was curious as to whether I would be correct in thinking this as I need to buy some parts for it and want to make sure they are correct before I go ahead with it.
Thanks for all the help I can get
Being in the UK your engine and vin numbers do not match ours in the US.  However based on looks it's between a '89 and '92.
Thanks for your help, my thoughts were between 89 and 92. From the engine I was fairly sure its 89 but wanted to make sure. Just not a hundred percent on the frame which looks to be 89/90. The only reason I ask is the brake pads seem to be different between 89 and 92 for the rear caliper. But then there is only 1mm difference in the brake pad size so cant be too much of an issue to retro fit if they are wrong.
Cheers for the confirmation anyway, much appreciated
