Gear selector shaft pressed in
Greetings. Today I've crashed on left side of my DRZ400. Gear lever was totally curved (fixed on video). Main problem: gear selector shaft pressed in (inside) engine! I can't change gear when it pressed in. If I pull it back from engine, then gearbox works correct (I can change gear). But selector shaft not fixed.
What I can do? Dismount right engine crank case cover first?
Edited by Paranoia
