2001 cr250 clutch bolts
Hi guys,
Redneck madness continues. Opened up the clutch to see all the bolts are mismatched, see attached photo.
Basically I want to replace these bolts with the correct ones for my clutch (That secure the springs)
Can someone please inform me of the correct set for a 2001 cr250? Links of any sort (amazon, ebay, etc) are appreciated. Or if its a sizing thing I can go get at my local hardware store.
Those bolts are not anything special, any decent 6mm bolt the right length with a hard washer that covers the springs and doesn't foul on anything will work perfectly fine. All they do is hold the spring pressure, which isn't actually that high. As stupid as it seems, that panel bolt would work fine, apart from the wear from the spring moving. And the imbalance from being different to the rest. And the difficulty tightening it properly with a pk screwdriver. I'm not saying to replace all the rest with those though 🤣
Going oem is always going to be safest, but some things don't HAVE to be.
