Kevin Taylor Posted September 26, 2019 What are you thoughts on boil overs, sometimes on real technical stuff our bike s boil over, radiator ice? Or cooling fan kit? Any thoughts or experience with either , thanks Share this post Link to post Share on other sites
William1 My Rides (2) Posted September 26, 2019 Two solutions. Ride faster or get a fan. 5 1 Share this post Link to post Share on other sites
highmarker Posted September 26, 2019 On that bike, drain all the coolant tipping the bike back and forth, put the exact book spec back in. It'll be a little below the fins because ktm has small expansion tanks on the rads. 50/50. 70/30 your call no magic sauce needed. That will help 90% of those that complain about boiling. I run a cpu fan and kdx overflow bottle also, but it's rarely required. 1 Share this post Link to post Share on other sites
spaceboy My Rides (2) Posted September 26, 2019 A 70/30 mix over the usual 50/50 mix of coolant and a fan will solve the problem. 1 Share this post Link to post Share on other sites
CDNSXV Posted September 26, 2019 $15 computer fan and switch. Share this post Link to post Share on other sites
CAPT ED My Rides (4) Posted September 26, 2019 41 minutes ago, CDNSXV said: $15 computer fan and switch. More info please : what size of fan , how much airflow CFM , bearings or sleeve , there are thousands of computer fans out there ? Share this post Link to post Share on other sites
BOAB Posted September 26, 2019 2 hours ago, Beta300recat said: Beta Honda 1 Share this post Link to post Share on other sites
Beta300REcat Posted September 26, 2019 1 minute ago, BOAB said: Honda Air cooled? 2 Share this post Link to post Share on other sites
BOAB Posted September 26, 2019 9 minutes ago, Beta300recat said: Air cooled? Doesn't boil over. And just because I ride an air cooled bike doesn't mean I am not familiar with liquid cooled. My sons both have CRF450Rs that I have spent a fair amount of time on. I just happen to like the simplicity of air cooled, when I started riding the only liquid cooled bike I can remember was the Suzuki 750 water buffalo. 1 Share this post Link to post Share on other sites
jeffrey sisti Posted September 26, 2019 The ice isn't gonna do anything but cost you extra money. I use Prestone in my bike and in my Toyota Tacoma, it also has an aluminum engine. Get yourself a fan kit, the highest cfm that you can get for that bike. Call your local bike shop. 4 Share this post Link to post Share on other sites
SteveThe Snakes My Rides (8) Posted September 26, 2019 You can set the trailtech fan to come on at a lower temp to prevent boil over. Share this post Link to post Share on other sites
Beta300REcat Posted September 26, 2019 1 hour ago, BOAB said: I started riding the only liquid cooled bike I can remember was the Suzuki 750 water buffalo. Had an opportunity to ride one of those. Went down the driveway and turned around. Had a loose head set. I learned the hard way on a DS185; never ride a motorcycle that isn't 100%. Share this post Link to post Share on other sites
knobbytrav Posted September 26, 2019 I use Evans and a Trail Tech fan kit in my 300. Share this post Link to post Share on other sites
Drop-Bear My Rides (3) Posted September 26, 2019 No offence Intended. But, you do bleed the air out of the radiator yeah? No one mentioned it, so thought I would. 2 1 Share this post Link to post Share on other sites
Mike Constant Posted September 26, 2019 You might be running a little lean. Happens to me all the time. I usually start with moving the needle clip down a notch. If that doesn't help use a bigger main jet. Share this post Link to post Share on other sites
Knightly Posted September 27, 2019 You might be running a little lean. Happens to me all the time. I usually start with moving the needle clip down a notch. If that doesn't help use a bigger main jet. If your on the main jet in technical conditions, your a better rider than me... or anyone for that matter.[emoji846] 2 Share this post Link to post Share on other sites
Knightly Posted September 27, 2019 +1 Trailtech fan and Evans. Share this post Link to post Share on other sites
