Angelo Posted September 26, 2019 So just rebuilt my clutch and put all new plates and stuff on but when I put it back together the oil was real milky and I had no collect in the radiator so I believe it’s going in the case what should I do to stop this Share this post Link to post Share on other sites
Smoking 2's Posted September 27, 2019 (edited) 14 hours ago, Angelo said: So just rebuilt my clutch and put all new plates and stuff on but when I put it back together the oil was real milky and I had no collect in the radiator so I believe it’s going in the case what should I do to stop this Did you reuse side case gasket? Or Water pump impeller seal needed Once seal or seals replaced use a cheap oil like atf type f and change every hour a few times at least to flush out water Edited September 27, 2019 by Smoking 2's Share this post Link to post Share on other sites
snb73 Posted October 5, 2019 I had the same issue with my son's 05RM85.I replaced the impeller, 2 bearings and seal. All the parts were around $30. It's not a difficult job at all. Took about 1 hour to complete. 1 Share this post Link to post Share on other sites
