zacksmith03 Posted September 27, 2019 My 2006 wr250f has 2 different points at which it idles. One is normal idle, but if huh you rev it up past the 2nd idle point it will stay there until I let the clutch out in gear to get the rpms down. Does anyone know exactly what the problem is? Also the bike bogs a bit on the low end and at about 3/4 throttle. Ik the jetting is off and I think that's what is causing it, but I dont know how to jet the bike properly for my elevation. Share this post Link to post Share on other sites
KRAYNIAL My Rides (7) Posted September 27, 2019 It's called hanging idle. You have an air leak. Most likely at a torn airboot, bad hot start or hot start cable, missing fuel screw oring, etc etc. Share this post Link to post Share on other sites
