Yamaha YZ250FX Starting Problem
Can somebody help me please? I have a 2015 YZ250FX and the electric start has packed up. After scratching my head I have found that the connectors on the 3 x relays sat below the battery have corroded and the wires have come away. I have no way of knowing which terminal the wires belong to. I have 2 options. I either buy a new wiring loom or I can try to repair the connectors. Does anyone have a photograph of the connectors so that I can put them back on the correct terminal. Thank you
Shop manual will have a wiring diagram and a bit of work with a multimeter will tell you which wire goes where.
OR you could spend hundreds for a new wiring harness and dozens of hours to completely tear the bike apart to install it.
Choice is yours.  ?
Hint:  Shop manuals can be found free online if you look.
As CDNSXV said.  The manual has wire routing diagrams that when studied for a good amount of time will provide insight.  I'd recommend coloring each wire a different color in the manual, it makes more sense then.
Edited by Honeybagder
  • 2 years later...
Choice is yours.  ?
Have you any success with the wires. I have similar issues with the starter and  cut out of the engine? Please let me know if you have the pics of the  3 x relays? You can post pics here.
Edited by tjrasor
