Paul_DRZ400S Posted September 27, 2019 I have a 2000 DRZ 400 s. I went to replace the rear bearing and found no center spacer and i have been running it like that for at least 2 years (when i bought it and put about 4000km on it. All offroad). Seeing I already have the bearings I wanted to create the center spacer out of mild steel pipe. 1 - do you see anything wrong with doing this? 2 - can someone give me the demensions for the rear wheel cneter spacer Thank for checking out my questions. Share this post Link to post Share on other sites
Dmouse Posted September 27, 2019 I would just go OEM, that area is prone to corrosion and not sure if steel is the right material to use for it Share this post Link to post Share on other sites
Erik Marquez My Rides (5) Posted September 27, 2019 SPACER, BEARING, 64731-29F00 $19 and it will be at your door step in a few days 1 Share this post Link to post Share on other sites
dad2u Posted September 27, 2019 I echo the go oem suggestion: water does ingress here frequently, and your steel will be a serious corrosion problem. Additionally, you would really need to have the exact dimensions as this is a critical part of the rear bearings bolt up. I am astounded that you did not have bearing failure in the past: if your rear axle was torqued to the full spec, with no internal spacer, then the lateral pressure on the axle and the side spacers would transfer to the inner races of the bearing sets (all 3) and they would have nothing inside the hub to push back, so the inner races would have all been displaced towards the inside of the hub, putting terrible side forces on the balls in the sets of bearings. I omitted a spacer once on a KLR and it destroyed the bearings in 3 km! 1 Share this post Link to post Share on other sites
