neutral between 2nd and 3rd gear
I have a 2003 XR100R that I purchased as a project bike. i did a complete rebuild on the bike and put it back together with no issues. Except when i brought it out for its first ride I could not find neutral, I was confused as to what the problem was so i would just use the clutch. Then i found out that to find neutral I would have to shift in between 2nd gear and 3rd gear to find neutral. Any ideas what the problem could be? I really don’t want to have to split the cases on the bike again so if there’s another solution I would love to hear
Remove clutch cover...
Zillions of YouTube vids on what's in there and how it works.
The only way that would work is if when you go to second, you're actually going past it into neutral. If you take off the clutch cover, you'll see a shift star, you can put a 10 T on it and shift through gears and that will give you a good indication what's up.
