mirage100 Posted September 28, 2019 Is there Anyone here who has installed a electric starter on there XR650R have any problems with it starting cold? Share this post Link to post Share on other sites
martinfan30 My Ride Posted September 28, 2019 This could be an issue with low cold cranking amps with your battery. Share this post Link to post Share on other sites
mirage100 Posted September 28, 2019 Thanks for the reply. New battery heated shop. Was told by the maker of the kit that on some XR650R it just won't crank cold. They said install a programable CDI box and change the timing on the start point . I THINK. I know programable CDI . Told to put MSD-4217 CDI and MSD-8232 coil. If that is what I got to do I guess I will. BUT I don't understand. Why most will crank cold but a few won't. I am the type of person on WHY. 1 Share this post Link to post Share on other sites
martinfan30 My Ride Posted September 28, 2019 I wonder if initial timing was different on different model years. Share this post Link to post Share on other sites
mirage100 Posted September 28, 2019 I have thought about that. I have looked up the part # for 2000 Xr650R for both CDI and Flywheel and 2007 # . they are all the same.. I am REAL discouraged with all this. Share this post Link to post Share on other sites
mirage100 Posted September 29, 2019 If stock is 6 degree BTDC where would I want it to fire for cold start up? Share this post Link to post Share on other sites
martinfan30 My Ride Posted September 29, 2019 Take into consideration that your cam chain may be worn/stretched and adding to the issue. Share this post Link to post Share on other sites
martinfan30 My Ride Posted September 29, 2019 Retard the timing slightly for easier starts. (If using a programmable cdi) Share this post Link to post Share on other sites
mirage100 Posted September 29, 2019 I do not know how to do that . I am trying to find out the timing of a 96 XR400. I think it is different . I hope I can get the XR400 CDI and it will fix it. I have not confirmed this. Anyone out there no the timing spec on the 96 XR400? The XR650R is 6 degrees BTDC so if the XR400 is 8 degrees BTDC do you think that would help? Share this post Link to post Share on other sites
mirage100 Posted September 29, 2019 I am not using a programable CDI. I am trying not to use one. Don't have a windows computer and they don't sell the hand held program box any more. If I could find someone to do a program set up I would buy one. Share this post Link to post Share on other sites
