Griggy Posted September 28, 2019 Hey guys I've got a drz 400s 7800miles with a fmf power bomb and power core 4 exhaust, 3 x 3 air box mod and jd jet kit. I followed the instructions from the jd jet kit but it smelt like it was over fueling said a friend riding behind me it also when standard used to wheelie by just pulling the rev Wot in second but doesn't seem to do that anymore so feels like I've lost power, I'm not sure it's because the exhaust takes low end torque and makes it high end or my tuning is off. I've looked at other forums but most not in the UK and advice would be much appreciated. 1 Share this post Link to post Share on other sites
Griggy Posted September 28, 2019 I'm thinking because I'm pretty much sea level15522.54th clip blue pin2.75 screwWhich I think I have done but lost power, I'm no wheelie kind of guy but when you do power mods and lose this ease to wheelie these surely a power loss Share this post Link to post Share on other sites
ohiodrz400sm My Rides (2) Posted September 28, 2019 Did you do all of these mods at once? Share this post Link to post Share on other sites
Griggy Posted September 29, 2019 Yea I bought the exhaust and a jet kit thinking it would just work and put them on at the same time Share this post Link to post Share on other sites
ohiodrz400sm My Rides (2) Posted September 29, 2019 Yea I bought the exhaust and a jet kit thinking it would just work and put them on at the same timeDon't the instructions say to use a larger main for a full exhaust? I've heard the newest kits now recommend a 170.I would double check to make sure everything is assembly correctly. I did the 3x3, jet kit , and a White Bros slip on at the same time many years ago. The bike gained power everywhere. Share this post Link to post Share on other sites
bumtarder My Rides (3) Posted September 29, 2019 I run a 170 main on a stock displacement motor and it pulls hard everywhere.My bike also likes the red needle at clip 3 down low.Be careful that the needle moves freely within the slide and the idle reacts to the fuel screw and the small 0-ring under the top cap stays in place. Share this post Link to post Share on other sites
Griggy Posted September 29, 2019 Are you guys at sea level? I think I'm around 0-300 meters. it does suggest the biggest jet in the kit with a performance exhaust but it smelt of fuel and didn't increase in performance Share this post Link to post Share on other sites
ohiodrz400sm My Rides (2) Posted September 29, 2019 Are you guys at sea level? I think I'm around 0-300 meters. it does suggest the biggest jet in the kit with a performance exhaust but it smelt of fuel and didn't increase in performanceThe lower the elevation, the more oxygen available, the richer the settings need to be. Get the service manual, double check the float level and verify you assembled everything correctly. Share this post Link to post Share on other sites
Griggy Posted September 29, 2019 My instruction which I followed but since doing some research the 25 isn't suited I'm better with the 22.5 since I don't have the extended screw but I'm not sure how I'd need it. I'll strip it out when I get chance clean it up and spend care rebuilding Share this post Link to post Share on other sites
ohiodrz400sm My Rides (2) Posted September 29, 2019 My instruction which I followed but since doing some research the 25 isn't suited I'm better with the 22.5 since I don't have the extended screw but I'm not sure how I'd need it. I'll strip it out when I get chance clean it up and spend care rebuilding It's my understanding they have updated the kit to include richer mains and better instructions concerning exhaust and cam.JD Jetting is known for their customer service. You should call them direct tomorrow. 1 Share this post Link to post Share on other sites
Griggy Posted September 30, 2019 It's an American number which I was expecting so I've emailed them through the contact on the website I'll let you know how it goes. Much appreciate the help would be great to get it running right again it's so disheartening to ride it and feel its lost power Share this post Link to post Share on other sites
Griggy Posted September 30, 2019 I've had my reply from jd they've said that "With your exhaust , the bike will not need more than a 160 main jet .The updated settings are for the new Akropovick race exhaust that has a very large header." I've asked what they suggest and told my 160 main 25 pilot and blue pin 4th clip 2 1/2 turn screw so I'll try this when I get chance Share this post Link to post Share on other sites
