Jimmy Pascol Posted September 28, 2019 (edited) Tired of fooling with the points type ignition on my XT flat tracker - with no lights of course. Thinking about a PVL or similar set up but the cost is frightening at approx. $600 USD. My old used pickup truck only cost $1500 and I brought my first baby home from the hospital in 1984 for a little over $400 out of pocket. I just can't pull the trigger on a $600 CDI gadget unless it will save money, make life easier or create more spare time. Read some comments stating they are not 100% plug and play so why buy something else to fiddle with when I already can do that with points? Change my mind. Edited September 28, 2019 by Jimmy Pascol Wife and I hv bn happily married 15 years = she's happy,, I'm married. Share this post Link to post Share on other sites
motoxvet Posted September 28, 2019 I have both types of bikes, points and CDI. I'd only spring for it if it was guaranteed plug & play. Did they ever make a later XT with CDI ignition? You could probably get one of those pretty cheap. Up to you...Have you looked at the spark timing with a timing light? Does it look pretty stable or does it shift from a little advanced to a little retarded? If it's pretty stable and points are still readily available, I'd say not much gain. Share this post Link to post Share on other sites
Truman Sparks Posted September 28, 2019 HEI ignition conversion Share this post Link to post Share on other sites
motoxvet Posted September 28, 2019 (edited) Just what Jimmy didn't want to do - mess around with the conversion to his wiring. Admittedly, the price is right and it could be a solution with an easy-to-find part. I bet you could find a NEW one for cheap too. I was curious so I saw that a module like a Duralst DR-124 has the pin config shown. It could work. From Autozone was $35 but I bet you could get it cheaper. I googled "GM HEI electronic ignition module" and along with all the images, there are a lot of basic schematics too. The GM 4 pin may be easier to use...? Edited September 28, 2019 by motoxvet Share this post Link to post Share on other sites
Jimmy Pascol Posted September 28, 2019 (edited) 1 hour ago, motoxvet said: Just what Jimmy didn't want to do - mess around with the conversion to his wiring. Admittedly, the price is right and it could be a solution with an easy-to-find part. I bet you could find a NEW one for cheap too. I was curious so I saw that a module like a Duralst DR-124 has the pin config shown. It could work. From Autozone was $35 but I bet you could get it cheaper. I googled "GM HEI electronic ignition module" and along with all the images, there are a lot of basic schematics too. The GM 4 pin may be easier to use...? That's too complicated for a Georgia boy like me. I have trouble with a flashlight. But wait, Rex's Speed Shop has a unit for $224 USD! Look at it. Anybody got the skinny on that? Edited September 28, 2019 by Jimmy Pascol Share this post Link to post Share on other sites
motoxvet Posted September 28, 2019 Again, if it guaranteed plug and play, that price won't hurt quite so much. Share this post Link to post Share on other sites
Jimmy Pascol Posted September 28, 2019 (edited) 23 hours ago, motoxvet said: Again, if it guaranteed plug and play, that price won't hurt quite so much. The full race unit at Rex's is just over $300 USD. I can enjoy that much pain better than twice as much for the PVL. Points are a pain in the azz but you can always make it run at least. If the electronic unit lays down it's going to hurt a lot worse. I'm going in! Taking one for the team! (Asked my wife what she wanted for her birthday; she said either a diamond ring or a Mercedes. Bought her a diamond ring because I couldn't find a cubic zirconium Mercedes for only $50) Edited September 29, 2019 by Jimmy Pascol 1 Share this post Link to post Share on other sites
BigDaddy22 Posted September 29, 2019 On my HL 500 replica, I used an 81' XT motor that came stock with a CDI ignition but I didn't get the CDI box when I purchased it. I bought the Rex Speed Shop unit and it is great. Made for ez starting and it NEVER kicks back when trying to fire it up. 1 1 Share this post Link to post Share on other sites
Jimmy Pascol Posted September 30, 2019 On 9/29/2019 at 9:28 AM, BigDaddy22 said: On my HL 500 replica, I used an 81' XT motor that came stock with a CDI ignition but I didn't get the CDI box when I purchased it. I bought the Rex Speed Shop unit and it is great. Made for ez starting and it NEVER kicks back when trying to fire it up. Did you have to do a lot of rewiring? All I need is spark at the cylinder. I think the simplest answer is going to be the race unit from Rex. The last thing I need is another half-baked project bike in the garage. 1 Share this post Link to post Share on other sites
BigDaddy22 Posted September 30, 2019 4 hours ago, Jimmy Pascol said: Did you have to do a lot of rewiring? All I need is spark at the cylinder. I think the simplest answer is going to be the race unit from Rex. The last thing I need is another half-baked project bike in the garage. I bought the SR2, this unit: https://www.rexs-speedshop.com/product/sr400-sr500-cdi-unit-1979-97/ Advertised as plug & play. But all I had was the 81' motor and that had the connector from the mag cut off. So I cut the connectors off the Rex unit and wired the 5 (or so) wires from the mag to the Rex SR2 and 1 or 2 more to the coil & kill button. They do have the SR1 for 1978 (points?) models: https://www.rexs-speedshop.com/product/yamaha-sr500-cdi-unit-1978-e/ Both these units are under $100, but you need the stator kit to generate the spark pulse... I assume you are looking at the RMK-4? Share this post Link to post Share on other sites
jack black Posted September 30, 2019 Hmmm how many sets of points can I buy for 300 bucs? 50 years worth? sorry I aint made of money. Share this post Link to post Share on other sites
