crackerjac Posted September 28, 2019 I received a new aftermarket Keihin PWK 38 with some parts in trade and at the moment the only bike I could possibly use it on would be the CRF230F. Mostly stock with ported intake and open air filter and 250X exhaust. Too much carb? or with some jetting mods would it work? Thoughts on jetting to start off with? Came stock with Keihin #55 pilot #170 Main Did a a search here and Google but brought up nothing. Share this post Link to post Share on other sites
SteveThe Snakes My Rides (8) Posted September 28, 2019 ?? Share this post Link to post Share on other sites
adnohguy Posted September 29, 2019 For any carb over 32mm on a 230f:34,36 or 38 mm carb: Custom, 1 off, oversized intake valve(s)Custom, 1off, porting.Custom,1 off, intake manifold.Custom 1 off air filter housing to carb hose. Sounds like a 4 valve Suzuki cylinder head with 300cc build for Greenhuman Of purchase a new 300 cc klx and shoe horn the engine in a 230 just so you can use a 38 mm carb. (Maybe) 1 Share this post Link to post Share on other sites
crackerjac Posted September 29, 2019 14 hours ago, adnohguy said: For any carb over 32mm on a 230f: 34,36 or 38 mm carb: Custom, 1 off, oversized intake valve(s) Custom, 1off, porting. Custom,1 off, intake manifold. Custom 1 off air filter housing to carb hose. Sounds like a 4 valve Suzuki cylinder head with 300cc build for Greenhuman Of purchase a new 300 cc klx and shoe horn the engine in a 230 just so you can use a 38 mm carb. (Maybe) Kinda figured that would be the case, lol. It's a 450X frame so maybe it's time to finally find a larger motor for this frankin bike. Share this post Link to post Share on other sites
SteveThe Snakes My Rides (8) Posted September 30, 2019 Just because you put a gigantic carb on a bike doesn’t mean it will perform. The size of the ports are so small you may have a very difficult time jetting it and having it run well. Share this post Link to post Share on other sites
bajatrailrider Posted September 30, 2019 38mm carb 230 don't even think of it 1 Share this post Link to post Share on other sites
VortecCPI My Rides (6) Posted September 30, 2019 (edited) That is a a LOT of carb. Back in the old days 300cc 2T sled engines used 38mm carbs. Edited September 30, 2019 by VortecCPI Share this post Link to post Share on other sites
bajatrailrider Posted October 1, 2019 Going back more old days tt500/650cc. 38mm carb. 1 Share this post Link to post Share on other sites
Don Tiemann Posted October 1, 2019 I looked at a used Yamaha Tenere 250 a couple of weeks ago. Prior to going over there to take a look, I asked the seller on the phone if his model had EFI or a carb. He said it had the expensive Keihin PWK pumper carb (?) Geez never seen one of them. So I headed over there and the bike had EFI. Geez. I don't know what that guy was smokin'. 1 Share this post Link to post Share on other sites
SteveThe Snakes My Rides (8) Posted October 1, 2019 There is your 38mm PWK on a 125 stock. But not a four stroke and that one is bored out to 39.5mm. ? 2 Share this post Link to post Share on other sites
bajatrailrider Posted October 2, 2019 I looked at a used Yamaha Tenere 250 a couple of weeks ago. Prior to going over there to take a look, I asked the seller on the phone if his model had EFI or a carb. He said it had the expensive Keihin PWK pumper carb (?) Geez never seen one of them. So I headed over there and the bike had EFI. Geez. I don't know what that guy was smokin'. That goes along with my friend. He had a 01 Dodge turbo Diesel sitting for years. I asked for months to buy it. Many times asked him 5 so stick or 6 sp. It had no shift ball he said many times 5 sp. Had it towed from beach to my house. 6sp stick wow owner does not know how many gears There is your 38mm PWK on a 125 stock. But not a four stroke and that one is bored out to 39.5mm. [emoji2956] I be there in a month I want to ride it 1 Share this post Link to post Share on other sites
SteveThe Snakes My Rides (8) Posted October 2, 2019 41 minutes ago, bajatrailrider said: I’ll be there in a month I want to ride it Well check out the turning radius. It doesn’t turn. Your just suppose to lean it over. ? 1 Share this post Link to post Share on other sites
