tylerbernauer Posted September 28, 2019 Hello, Im pretty new to the whole suspension thing so I'm wondering if someone could help me out. I have a 2007 CRF250R shock that I decided to rebuild as practice. I pulled it apart and noticed the peening was already filed off so I checked the shim stack to see what changes have been made. Would anyone be able to point out what these changes would of accomplished. I'll post the stack I found and the stack I believe to be stock. Thanks in advance. STOCK STACK THAT I HAVE Compression COMPRESSION 44.2x7 44.2x7 44.15x6 44.15x4 37.15 34.10 30.15 28.10 42.2x2 44.25x2 40.25 40.25 38.25 38.25 36.25 36.25 34.25 34.25 32.25 32.25 31.25 30.25 30.25 28.3 29.3 26.3 28.3 24.3 27.3 22.3 26.3 PLATE 44.5mm X 5mm 25.3 44.3 24.3 23.3 22.3 25.6x3 Rebound REBOUND 40.2x2 40.2x6 25.1 28.2 40.3 40.3 38.3 38.3 36.3 36.3 34.3 34.3 32.3 32.3 31.3 30.3 30.3 28.3 29.3 26.3 28.3 24.3 27.3 29.3x6 26.3 Share this post Link to post Share on other sites
chelder Posted September 29, 2019 Interesting stack, for sure the compression is really soft and a lot of low speed rebound and a faster high speed rebound, Would need to put in into restackor, one of the pros will be along soon.... Share this post Link to post Share on other sites
mog Posted September 29, 2019 The thing is the 0.1mm cross over shims allow the high speed stack to support the low speed stack more ,and the 44.25 in the high speed mean it's much former there than STD ,like much much firmer ,the clamp us much smallerThat mid part if the stack confuses things ,I think the softer clamp makes it softer overallThe rebound is what most people use to get some control of low speed rebound Share this post Link to post Share on other sites
chelder Posted September 29, 2019 Ah yes I missed the .25's Share this post Link to post Share on other sites
tylerbernauer Posted September 29, 2019 Thanks for the responses guys. A little over my head but i'm learning. Once i get the tools ill pull the forks apart, im assuming they will be valved as well. I have the shock back together and it rebounded good, although it is pretty hard to push down. There is also a small amount of noise during the last 1/4" of rebound or so. Could this be the top out spring or do you think I have some air left in there? Share this post Link to post Share on other sites
MX Tuner Posted September 29, 2019 Mog, you're still a moron. The stack you list is very similar to what I'd do. I wouldn't quite do it the same way but the end result would be close to what I'd do. Its taken me almost 25 years of doing suspension to know what shims really do what in respect to the changes. If it works, I wouldn't mess with it. As long as you have some clicker adjustments available, you should be in good shape. I've seen some really f*cked up shim stacks- I just shake my head and put a good stack in it. The stack you show looks very reasonable and should work well. Share this post Link to post Share on other sites
mog Posted September 30, 2019 I guess that was a joke and I missed it ? Share this post Link to post Share on other sites
chelder Posted October 3, 2019 5 hours ago, MX Tuner said: Nope, no joke. I have no idea what's going on here but seems a bit harsh Mog is always coming in here helping people out and is a valuable contributor from everything I have seen. Anyway thanks Mog 2 Share this post Link to post Share on other sites
tylerbernauer Posted October 3, 2019 Hey mog, i've done some researching on here and saw you suggested 14mm dia Standard HSS Annular Hole Cutter c/w Arbor for doing Showa shocks, which i believe is a 10.5mm ID if i remember correctly from your thread. Do you still use this or have you found a better way? If you do still use it do you know what size you use for KYB shocks. I don't have one to currently check with. I'm currently trying to get a little collection of suspension related tools. I ordered a few Factory Wrench Tools for KYB SSS and Showa Twin Chamber forks. https://factorywrenchtools.com/. Ive also ordered a few of those race tech compression adjuster sockets. Thanks Share this post Link to post Share on other sites
mog Posted October 4, 2019 Yes still use it , not sure on the kyb however Share this post Link to post Share on other sites
