New studs required!!!
Redoing a yz125 motor to include putting in all new engine case studs.   First let me say, those things can be a pain I. The ass to remove!  Now that they are out I want to put in the best studs possible.   The factory studs had some mild rust.   Should I go with new factory studs or find some other studs that resist runway and hold up longer?
I assumed I would use red loctite when installing but was going to see if the manual said anything on stud replacement.  What’s the best way to install?
thanks for the help!
Never needed to replace them. A surface rust in no need to replace.
Install with double nut like any stud.
  • Helpful 1
always used one of these for studs - also good for installing studs because you can use a torque wrench on it
  • Helpful 1
