j cal Posted September 29, 2019 (edited) Where does the top bolt, bolt into? Can't seem to find instructions online! Edited September 29, 2019 by j cal Share this post Link to post Share on other sites
Puddn421 Posted September 29, 2019 Is there an upper chain roller there? Share this post Link to post Share on other sites
SmokinJoe Posted September 29, 2019 Thought there was a clamp that went around the frame similar to how a skip plate clamps on. 1 Share this post Link to post Share on other sites
scoobydoo Posted September 29, 2019 52 minutes ago, SmokinJoe said: Thought there was a clamp that went around the frame similar to how a skip plate clamps on. correct, there is a clamp Share this post Link to post Share on other sites
j cal Posted September 29, 2019 Crap I don't have that okay thanks guys! Share this post Link to post Share on other sites
YZDOC Posted September 29, 2019 17 minutes ago, j cal said: Crap I don't have that okay thanks guys! So I take it you have a pre 2002? You can use a electrical 1/2 clamp with bolt and nut if you have the guards. 2 Share this post Link to post Share on other sites
j cal Posted September 29, 2019 So I take it you have a pre 2002? You can use a electrical 1/2 clamp with bolt and nut if you have the guards. Yeap, 01, thank you!!! 1 Share this post Link to post Share on other sites
YZDOC Posted September 29, 2019 49 minutes ago, j cal said: Yeap, 01, thank you!!! Might need a 1” on that down pipe part of the frame. 1/2” is the sub frame. So measure first. 1 1 Share this post Link to post Share on other sites
