Borthwick203 Posted September 29, 2019 (edited) Will the Xtrig preload adjuster fit on a ‘04 CR250R rear shock? Which year shock body are compatible with the Xtrig preload adjuster? 02-08 CR/CRF suspension appear to be very similar Xtrig preload adjuster fits ‘06+ CRF250R/CRF450R I’ve had ‘08 CRF250R suspension before, that was damaged during shipping and never mounted up Currently using the stock ‘04 CR suspension Edited September 29, 2019 by Borthwick203 Share this post Link to post Share on other sites
jeddclampette Posted September 29, 2019 look up the part number on the OEM shock spring adjuster collar and see if the part number is interchangeable / the same for the years bikes you're asking about. IF they are, then you've good to go. Share this post Link to post Share on other sites
