hondino Posted September 29, 2019 I dented the treatment on the fork rod by testing a tool that I usually don't use. About 5 mm above the nut and then just above, how can I at least round the marks? Share this post Link to post Share on other sites
n2dirt Posted September 30, 2019 20 hours ago, hondino said: I dented the treatment on the fork rod by testing a tool that I usually don't use. About 5 mm above the nut and then just above, how can I at least round the marks? You can replace the rod. Check and see if it makes it to the shaft seal. If not. don't worry about it. Share this post Link to post Share on other sites
hondino Posted September 30, 2019 yes, I checked, the cartridge oil seal is far from the notch, maybe it comes close to the bush but it shouldn't touch it for 1 or 2mm. I don't know where to find the new rod is Showa 12mm. Share this post Link to post Share on other sites
