Andrew Puetz Posted October 2, 2019 The force is strong with this one. I may have to upgrade. Once it hits BYOB I will fill up some spare time with builds 2 Share this post Link to post Share on other sites
KRAYNIAL My Rides (7) Posted October 3, 2019 8 hours ago, Gflo said: Just do it Bill. OK, that settles it, Gary. Hey, you got $11,289.63 I can borrow for a couple of weeks ? I think that's about how long the Kidney sale will take. 4 Share this post Link to post Share on other sites
dirtbird Posted October 3, 2019 (edited) 3 hours ago, KRAYNIAL said: I would put big red Sachs-ZF decals on the forks... ? Edited October 3, 2019 by dirtbird 1 1 1 Share this post Link to post Share on other sites
KRAYNIAL My Rides (7) Posted October 3, 2019 8 hours ago, dirtbird said: I would put big red Sachs-ZF decals on the forks... ? Actually, I'm thinking about finding some Ceriani decals....... Share this post Link to post Share on other sites
Ben500RR-S Posted October 3, 2019 Get that 300 RE. I will wonder if you ever do, if you'll ever go back to 4S. If I could have a pure offroad/enduro bike, it will be 2S. Even for a pure snowbike I know a 300 2S is where it is at for my lightweight/featherweight/bantamweight-ass. The big, heavy 500 is just keeping me in shape in my advancing=Vet age-=ha! 1 Share this post Link to post Share on other sites
KRAYNIAL My Rides (7) Posted October 3, 2019 RR version BYOB Build example: (stock tires, no damper system yet) 2020: 300 RR $9,199.00 Neutech TU bliss tire insert 18" Neutech TU bliss tire insert 21" Works Connection Rotating Brake and Clutch Clamp Handlebar Riser Kit Fasst Flexx Handlebars ARC Folding Front Brake Lever ARC Folding Clutch Lever Red Clutch Line, 2-stroke, +2 inch Billet Brake Clevis, Black BRP chain block Beta USA Front Axle Pull Rigid Handguard Mount risers Cycra Beta Pro Bend Hanguards TM Designs Clutch Cylinder Guard TM Designs Inner Subframe Protector Bulletptoof Swingarm Guard TM Designs Factory Ed. Rear Chain Guide TM Designs Rear Disc Guard Beta 2-stroke Exhaust Collar Cooling Fan Kit, 2 Stroke Carb Vent System 2 Suspension Support Package RR/RR-S Beta Racing Shock Adjuster made by Xtrig. 48mm Sachs fork spring 125/200/250/300 RR Rear Shock Spring 200/250/300 Shock Bladder & Cap Kit, 2019+ Beta Storage Tube Total: $12,356.18 Share this post Link to post Share on other sites
Ben500RR-S Posted October 3, 2019 (edited) BAB BuildAndBuy Do not delay. Money is no object. Enjoy powerful. Enjoy light. Enjoy handling better than any 4S BAB-you have been so-ordered. Edited October 3, 2019 by Ben500RR-S 2 Share this post Link to post Share on other sites
shrubitup Posted October 4, 2019 15 hours ago, KRAYNIAL said: Cooling Fan Kit, 2 Stroke This ain't no KatieM 300 Not needed. 2 1 Share this post Link to post Share on other sites
randysoo My Ride Posted October 4, 2019 On 10/3/2019 at 5:45 AM, Ben500RR-S said: Even for a pure snowbike I know a 300 2S is where it is at for my lightweight/featherweight/bantamweight-ass. My buddy has a CR500 converted to sno bike. but he said the carb kept freezing up on him. He had to put it on his 500exc because the fi worked better in the cold Share this post Link to post Share on other sites
Ben500RR-S Posted October 4, 2019 16 minutes ago, randysoo said: My buddy has a CR500 converted to sno bike. but he said the carb kept freezing up on him. He had to put it on his 500exc because the fi worked better in the cold Two strokes have more problems, that FI, in the cold. It is solved a couple of ways, carb jackets and engine jackets that keep the heat in the big hunks of metal or more commonly, carb heaters where the coolant is piped to machined pieces that clamp around the intake-sides of the carbs to eliminate the icing. It costs some money but the payoff is no icing and a motor that will run in the cold and snow. I had converted my BIL's KTM 300 and had installed both a SmartCarb and a carb heater from PST Powersports and it runs awesome. I used to have both a 1985 CR500R and a 1996 CR500R and can only imagine how nice it would have been to still have the 96 as a snowbike as the bikes were pretty awesome as woods-bikes, no matter what anyone says. FI is nice in the cold. No need to jet. No need for choke. Just twist and go, point and shoot. 1 Share this post Link to post Share on other sites
redrider144 Posted October 5, 2019 On 9/29/2019 at 4:02 PM, KRAYNIAL said: Is it ???? If KRAN the Ultimate 2T Hater gets one of these, Red the Ultimate Beta Hater is going to end up turning to the dark side. 1 2 Share this post Link to post Share on other sites
somethingnuw My Rides (6) Posted October 25, 2019 On 10/3/2019 at 7:38 AM, KRAYNIAL said: RR version BYOB Build example: (stock tires, no damper system yet) 2020: 300 RR $9,199.00 Neutech TU bliss tire insert 18" Neutech TU bliss tire insert 21" Works Connection Rotating Brake and Clutch Clamp Handlebar Riser Kit Fasst Flexx Handlebars ARC Folding Front Brake Lever ARC Folding Clutch Lever Red Clutch Line, 2-stroke, +2 inch Billet Brake Clevis, Black BRP chain block Beta USA Front Axle Pull Rigid Handguard Mount risers Cycra Beta Pro Bend Hanguards TM Designs Clutch Cylinder Guard TM Designs Inner Subframe Protector Bulletptoof Swingarm Guard TM Designs Factory Ed. Rear Chain Guide TM Designs Rear Disc Guard Beta 2-stroke Exhaust Collar Cooling Fan Kit, 2 Stroke Carb Vent System 2 Suspension Support Package RR/RR-S Beta Racing Shock Adjuster made by Xtrig. 48mm Sachs fork spring 125/200/250/300 RR Rear Shock Spring 200/250/300 Shock Bladder & Cap Kit, 2019+ Beta Storage Tube Total: $12,356.18 So many questions...what is a carb vent system 2? For an old guy who isn’t good is the 300 re worth the extra over the rr? This old guy is fat too so suspension needs work right away! Asking for a friend...... Share this post Link to post Share on other sites
shrubitup Posted October 25, 2019 3 minutes ago, somethingnuw said: ! Asking for a friend.... Tell your *ahem* friend that the RE is for looks and the RR is for riding. Springs easily obtained from after hours cycle. 1 Share this post Link to post Share on other sites
SigPig My Rides (7) Posted October 25, 2019 6 hours ago, somethingnuw said: So many questions...what is a carb vent system 2? For an old guy who isn’t good is the 300 re worth the extra over the rr? This old guy is fat too so suspension needs work right away! Asking for a friend...... I opted for the RE. I need to see what this KYB fuss is all about. 2 Share this post Link to post Share on other sites
somethingnuw My Rides (6) Posted October 25, 2019 (edited) 4 hours ago, SigPig said: I opted for the RE. I need to see what this KYB fuss is all about. Right! I’m afraid with my .....friends bulk...kyb’s will easier to work on too... it I haven’t seen a price comparison yet in Canada its a better looking bike imhop Edited October 25, 2019 by somethingnuw Share this post Link to post Share on other sites
Johnny Depp Posted October 25, 2019 (edited) Yes it's possible, just keep waiting 'til they are all gone.. If I had your money I'd burn mine.🤣 I guess you aren't too worried about fires in your riding area..Not a tree to be found. Edited October 25, 2019 by Johnny Depp Share this post Link to post Share on other sites
