DC597 Posted September 30, 2019 Has anyone made this happen yet? I know the 03 changed to an axel that’s 2mm bigger than the 02. Is it as simple as modifying the swingarm? Would kind of like to be able to throw on some Tusk wheels without hunting down an 03 swingarm. Share this post Link to post Share on other sites
FPMXer Posted October 2, 2019 If the axle is bigger then you should be able to use the wheel bearings from your bike in the 03'-07' hubs. Just make sure the OD of the bearings are the same between the new stuff and your old stuff. If not I'm sure you can find bearings with the proper OD to work with your axles. Then no mod's are needed. Share this post Link to post Share on other sites
turbo dan Posted October 2, 2019 The rear rotor diameter is different and the rotor goes from six bolts to four bolts. That's the big issue. The rear brake caliper bracket is different and will not interchange. 1 Share this post Link to post Share on other sites
