TE150 Jetting and Powervalve
Use 2019 jetting ,PV play with it till you like it
I noticed turning the PV on my 19 150 didn't make nearly the difference that it did on my 2020 300.... I went 1/2 out so far and it's probably 1/2 turn from flush. I may go a little more but it wasn't a drastic difference.
I'm running the stock spring. My bike only came with the yellow as an extra. As I understand it the stock is progressive and should be more aggressive (opening sooner) than the yellow already though?
Edited by StreetDoctor
It won't ,you only have say 15hp available when the pv starts to open ,it can't make a huge difference
I went to a Lectron and couldn’t be happier.  The power is almost electric feeling now.  Climbing hard tech is so easy with this setup.  Can’t say enough good things.  Bought mine from Slavens setup for the 150.  Had to lean it out 1/2 turn on the rod and been good ever since.  Mine’s running a hair rich like this, nice and torquey down low.  Love it.
I’ve traditionally played around with OV settings, swapped springs, etc but I really like stock on the 150.
