chunk81 Posted September 30, 2019 (edited) i have a 2011 crf450x i have no spark i changed the stator the coil and all fuses checked all plug connections all of them are ok i did notice there was 2 wires loose from the starter relay so i connected them back to the relay but still no spark any ideas? also the red wire going from the ignition switch to the coil is that positive or negative because when i connect a test light up to the positive of the battery and touch the red wire it lights up so its telling me its either a earth wire or theres a short or something could it also be a faulty ignition switch i have power to 2 wires the earth is good on it but the red wire going from the ignition switch to the coil has nothing i did look up all issues the same as what my problems are but nothing is working please help its killing me not being able to ride Edited September 30, 2019 by chunk81 Share this post Link to post Share on other sites
endo987 Posted October 1, 2019 here is a wiring diagram hope this helps 1 Share this post Link to post Share on other sites
YuriGagarin Posted October 2, 2019 8 hours ago, endo987 said: here is a wiring diagram hope this helps You have a higher res image of that? TIA Share this post Link to post Share on other sites
PhilthyX My Rides (4) Posted October 2, 2019 Have you checked the kill switch? 1 Share this post Link to post Share on other sites
endo987 Posted October 2, 2019 That is the only image I have Share this post Link to post Share on other sites
endo987 Posted October 2, 2019 found this one hope it helps 1 Share this post Link to post Share on other sites
chunk81 Posted October 10, 2019 thank you all for your help i finally found the problem it was my cdi unit i got a new one and fired up cheers guys 1 Share this post Link to post Share on other sites
endo987 Posted October 10, 2019 no problem, now back to riding??? Share this post Link to post Share on other sites
