Zack Brappp44 My Ride Posted September 30, 2019 I have a cr250 and am planning on putting new rings in it and i was able to get one of the 2 rings on the piston off but the other one seems like it is stuck on there and it wont come off. I tried cleaning it with degreaser and oven cleaner and then took a pick to it but it still wont come off. An suggestions on how to get it off to replace it or am i going to have to get a new piston? Share this post Link to post Share on other sites
HRC27 My Rides (2) Posted September 30, 2019 I'd go with a new piston. 1 Share this post Link to post Share on other sites
kyledfx Posted September 30, 2019 Why would you want to reuse the old piston? A top end job is rings/piston/piston bearing/pin and gaskets. The old piston is junk, I don't know anyone who would reuse an old piston. Do you really want to risk breaking a piston and really screwing up the motor over $100 or so? 1 Share this post Link to post Share on other sites
Zack Brappp44 My Ride Posted September 30, 2019 Why would you want to reuse the old piston? A top end job is rings/piston/piston bearing/pin and gaskets. The old piston is junk, I don't know anyone who would reuse an old piston. Do you really want to risk breaking a piston and really screwing up the motor over $100 or so? People just do a ring job all the time man 1 Share this post Link to post Share on other sites
HRC27 My Rides (2) Posted September 30, 2019 1 hour ago, Zack Brappp44 said: People just do a ring job all the time man Not when one of the rings are stuck in the piston. 3 Share this post Link to post Share on other sites
_MountainRider_ Posted September 30, 2019 People just do a ring job all the time man[emoji23] seems like you wouldn’t even have to post to get a good answer. You’d think if the rings don’t come off it’s time for a new piston and also just why not replace the piston? Never really heard of any long lasting motor that people just replace the rings on… Only time I’d deem a ring replacement okay is if I had to pull of the cylinder at like 7 hours and just did the rings while I was in there. Share this post Link to post Share on other sites
ss-racing My Rides (2) Posted September 30, 2019 (edited) 1 hour ago, HRC27 said: Not when one of the rings are stuck in the piston. This is correct ...unless you're in some kind of pinch and feel the need to squeeze some more time out of that piston. stuck ring means show-stopper if planning to re-ring a piston. Detonation or near seizure is usually what causes it ....very very seldom does oil do that. If you did a compression test, saw low compression and tore it down to find the problem , guess what, you found it. Edited September 30, 2019 by ss-racing Share this post Link to post Share on other sites
Fred29 Posted September 30, 2019 I have a cr250 and am planning on putting new rings in it and i was able to get one of the 2 rings on the piston off but the other one seems like it is stuck on there and it wont come off. I tried cleaning it with degreaser and oven cleaner and then took a pick to it but it still wont come off. An suggestions on how to get it off to replace it or am i going to have to get a new piston? How's the cross hatching on the cylinder wall? Don't even consider not doing the whole top end. Wiseco piston and OEM gaskets. Saving $60 on a cheap kit will burn you in the end. Share this post Link to post Share on other sites
Zack Brappp44 My Ride Posted September 30, 2019 How's the cross hatching on the cylinder wall? Don't even consider not doing the whole top end. Wiseco piston and OEM gaskets. Saving $60 on a cheap kit will burn you in the end. The cylinder could use a hone, there is no chips or scratches. Where is a good place to take it to get a hone job? Share this post Link to post Share on other sites
Fred29 Posted September 30, 2019 First I would measure the bore before you buy anything. Harbour Frieght sells bore measuring tools real cheap. Pick up a cheap micromator as well. $20 total. I just went through US Chrome and was happy with the results. I went all out and had mine stripped, plated, and honed back to OEM 66.4mm. If you go that route pick up a Wiseco kit and send them the cylinder and piston only. No rings needed for fitment. You can buy a hone ball, but I've heard horror stories because people overdo it. Share this post Link to post Share on other sites
kyledfx Posted October 1, 2019 1 hour ago, Fred29 said: You can buy a hone ball, but I've heard horror stories because people overdo it. yup, at one point i thought i could strait stone drill hone a worn stock steel bore out to a used first overbore piston... totally ruined it.. Share this post Link to post Share on other sites
