Cody Draper Posted September 30, 2019 So I bought a cheap headlight from Amazon for 20 bucks and it plugged right into my wiring harness great. When I started my Ktm the low beam was the only light to come on. I only ride off road trails. I will never need a low beam only a high beam. How do I wire it so when I turn on the switch only the high beam comes on? Share this post Link to post Share on other sites
MrKTMrider Posted October 8, 2019 (edited) On 9/30/2019 at 12:52 PM, Cody Draper said: So I bought a cheap headlight from Amazon for 20 bucks and it plugged right into my wiring harness great. When I started my Ktm the low beam was the only light to come on. I only ride off road trails. I will never need a low beam only a high beam. How do I wire it so when I turn on the switch only the high beam comes on? There should be a live wire for the high beam light. From there you could splice it into the low beam circuit or where it is currently running. Edited October 8, 2019 by MrKTMrider Share this post Link to post Share on other sites
