bajacaat Posted September 30, 2019 This doesn’t look normal... Share this post Link to post Share on other sites
Yzmaster Posted October 1, 2019 This doesn’t look normal... The gas cap breather hose will break down the grease in the stem and leak out the bottom. 1 Share this post Link to post Share on other sites
bajacaat Posted October 1, 2019 The gas cap breather hose will break down the grease in the stem and leak out the bottom.I found out Honda uses thin grease. Just need to clean and use better grease[emoji106]Thanks 1 Share this post Link to post Share on other sites
Gary Strombeck Posted October 1, 2019 19 hours ago, Yzmaster said: The gas cap breather hose will break down the grease in the stem and leak out the bottom. The stem center hole doesn't see the bearings. It's just a thru hole. Hondas have a tendency to weep as do some others. Next time you have the front end apart see how little grease Honda uses, then clean and add a bunch more. 2 Share this post Link to post Share on other sites
bweighmaster Posted October 1, 2019 Fuel hose not in play here . Myth ... pull it apart , use heavy , waterproof grease... 2 Share this post Link to post Share on other sites
bajacaat Posted October 2, 2019 Fuel hose not in play here . Myth ... pull it apart , use heavy , waterproof grease...Have some bel ray waterproof grease ready to go[emoji106] Share this post Link to post Share on other sites
Gibson5000 Posted October 2, 2019 That looks normal Share this post Link to post Share on other sites
