Christian Dawe Posted September 30, 2019 I bought a 2019 Suzuki drz 125L used and at full throttle it bogs like crazy. While driving in 5th gear or even second gear sometimes at low rpm if I give it full throttle it dies and at idle if I give it full gas it dies. I adjusted the float height to manufactures spec and pilot/air screw to 2 and a half turns out. Not sure why it does this but it’s infuriating and for a bike so new I’m not sure why it does this, any help is appreciated! Share this post Link to post Share on other sites
KRAYNIAL My Rides (7) Posted October 7, 2019 On 9/30/2019 at 4:34 PM, Christian Dawe said: I bought a 2019 Suzuki drz 125L used and at full throttle it bogs like crazy. While driving in 5th gear or even second gear sometimes at low rpm if I give it full throttle it dies and at idle if I give it full gas it dies. I adjusted the float height to manufactures spec and pilot/air screw to 2 and a half turns out. Not sure why it does this but it’s infuriating and for a bike so new I’m not sure why it does this, any help is appreciated! That bike is supposed to run like that. It's a 125cc with a tiny carb. You can only give it full throttle when you are at least half way through the rpm range. Even then, it won't be any difference from about 3/4 throttle on up. Very few motorcyles will allow you to go full throttle in gear from low rpms. Share this post Link to post Share on other sites
