Warstack Posted September 30, 2019 Don't want to have to rent a truck! Share this post Link to post Share on other sites
PhilthyX My Rides (4) Posted September 30, 2019 No but if you don't want to deal with lying it down, gas, oil etc can you just not remove the front tire and put it in standing up then deal with supporting it? Share this post Link to post Share on other sites
C2.0 My Rides (2) Posted September 30, 2019 Caravans have hitches that should support one of the hitch carriers if that's an option Share this post Link to post Share on other sites
BLAM Posted October 1, 2019 (edited) "Anyone fit a DRZ400SM into the back of a Caravan?" Gypsies. Edited October 1, 2019 by BLAM 1 Share this post Link to post Share on other sites
Warstack Posted October 1, 2019 1 hour ago, filterx said: No but if you don't want to deal with lying it down, gas, oil etc can you just not remove the front tire and put it in standing up then deal with supporting it? This is exactly what I was thinking. 1 hour ago, C2.0 said: Caravans have hitches that should support one of the hitch carriers if that's an option Plan to do this in future. My van has no hitch yet. Share this post Link to post Share on other sites
C2.0 My Rides (2) Posted October 1, 2019 Do you have stow n go? Have you measured the bike and van? Share this post Link to post Share on other sites
Warstack Posted October 2, 2019 Thx guys. Might just rent a truck. Share this post Link to post Share on other sites
Methotic My Ride Posted October 3, 2019 Not sure, but I managed to get a DRZ400S with dirt knobbies into a 2013 Ford Transit Connect. It was a tight fit with the handlebars but I still managed to squeeze it in. Share this post Link to post Share on other sites
Warstack Posted October 6, 2019 It fit! Removed front wheel. Quite easy actually. 3 Share this post Link to post Share on other sites
shuswap1 Posted October 6, 2019 (edited) Where there is will there is a way! I'm not sure how well the soft, very soft rear springs on a Caravan would support a hitch mounted bike anyway. I know my G Caravan would be bottoming out the suspension everywhere. Edited October 6, 2019 by shuswap1 Share this post Link to post Share on other sites
PhilthyX My Rides (4) Posted October 6, 2019 2 hours ago, Warstack said: It fit! Removed front wheel. Quite easy actually. Glad my suggestion worked and nice job tying it down to the seat mounts! 1 Share this post Link to post Share on other sites
C2.0 My Rides (2) Posted October 6, 2019 Where there is will there is a way! I'm not sure how well the soft, very soft rear springs on a Caravan would support a hitch mounted bike anyway. I know my G Caravan would be bottoming out the suspension everywhere. They are rated to tow like 3600 lbs or something like that. It should be fine I would think. When I had mine it didnt like to pull my boat and squatted pretty good but got the job done. Share this post Link to post Share on other sites
shuswap1 Posted October 6, 2019 28 minutes ago, C2.0 said: 1 hour ago, shuswap1 said: Where there is will there is a way! I'm not sure how well the soft, very soft rear springs on a Caravan would support a hitch mounted bike anyway. I know my G Caravan would be bottoming out the suspension everywhere. They are rated to tow like 3600 lbs or something like that. It should be fine I would think. When I had mine it didnt like to pull my boat and squatted pretty good but got the job done. Mine bottoms against the rubber snubbers if I put any weight in the rear or more than a couple hundred # on the hitch. I've always said first thing I should do is add another leaf to the single Dodge provides. But they are a very handy vehicle, why I keep mine. Share this post Link to post Share on other sites
Methotic My Ride Posted October 7, 2019 Taking notes. Next time I get stranded on the side of the road, I'll be flagging down all of the soccer moms for a lift LOL Share this post Link to post Share on other sites
Warstack Posted October 7, 2019 8 hours ago, Methotic said: Taking notes. Next time I get stranded on the side of the road, I'll be flagging down all of the soccer moms for a lift LOL LOL. Be honest, a lift won't be the only thing you ask for. 2 Share this post Link to post Share on other sites
Steve Perkins Posted April 10, 2020 I just hauled one home from Kentucky....in a Ford Escape! Really not bad.....took like 15 minutes to knock it down. Guy didn't think it would fit. Pull rear axle, remove rear wheel. Pull front axle, loosen 4 pinch bolts,remove front wheel. Pull front caliper bolts, loosen 8 front fork pinch bolts, drop front forks. Load her up. Total tools = 24mm wrench (or whatever weapon you want for the axle nuts) and a 12mm socket and extension. I hauled my other one in a minivan complete......drain the fuel and lay it on it's right side on blocks so you don't have to worry about the brake pedal popping the case if you hit a pothole on the way. Share this post Link to post Share on other sites
