Methotic My Ride Posted September 30, 2019 My beautiful Z Pro showed up in the mail today! Man this thing is LOUD! I love it. Although the increase in flow really threw off my jetting big time on the pilot. Fuel screw adjustment.. not good enough. Really reeks of fuel at idle. Running a 45 pilot currently. Big bog on a quick snap. Wont hold steady idle. Fuel screw all the way in and idle raises. Fuel screw 3 turns out and then sutters and dies. Should I be moving up or down on pilot? 42 or 47? I have both sitting on the bench. Share this post Link to post Share on other sites
Methotic My Ride Posted October 1, 2019 (edited) EDIT: also I duct taped the airbox since the previous owner thought it would be clever to drill 6 1" holes on the side cover. I'm sure that is a factor as well. Edited October 1, 2019 by Methotic Share this post Link to post Share on other sites
ohiodrz400sm My Rides (2) Posted October 1, 2019 The pilots follow a 0 2 5 8 progression, not sure where you got a 7?When you turn the idle screw in and the rpms rise what happens if you turn the idle back down to normal and try tuning again?What needle are you using and what displacement is the engine? Share this post Link to post Share on other sites
Methotic My Ride Posted October 1, 2019 1 minute ago, ohiodrz400sm said: The pilots follow a 0 2 5 8 progression, not sure where you got a 7? When you turn the idle screw in and the rpms rise what happens if you turn the idle back down to normal and try tuning again? What needle are you using and what displacement is the engine? Sorry, you are right. It's a 48 not a 47. Screw all the way in seems pretty smooth. 440 bore and EMN needle 4th clip. Fcr41 Share this post Link to post Share on other sites
Scottg07 Posted October 1, 2019 What pipe is it replacing? Stock? I didn't have to change jetting from my fmf to mrd. They are indeed a beautiful pipe! Share this post Link to post Share on other sites
Methotic My Ride Posted October 1, 2019 10 hours ago, Scottg07 said: What pipe is it replacing? Stock? I didn't have to change jetting from my fmf to mrd. They are indeed a beautiful pipe! No, it replaced a FMF powerbomb and spark arrestor. I also patched up air box. Share this post Link to post Share on other sites
Beta300REcat Posted October 1, 2019 14 hours ago, Methotic said: Sorry, you are right. It's a 48 not a 47. Screw all the way in seems pretty smooth. 440 bore and EMN needle 4th clip. Fcr41 What idle air jet are you running? Share this post Link to post Share on other sites
ohiodrz400sm My Rides (2) Posted October 1, 2019 You need to get an R diameter needle Share this post Link to post Share on other sites
Methotic My Ride Posted October 2, 2019 9 hours ago, ohiodrz400sm said: You need to get an R diameter needle I checked needle, cant remember which one I ordered. Turns out it is in fact EMR, not EMN. My mistake. Share this post Link to post Share on other sites
bumtarder My Rides (3) Posted October 2, 2019 So it's too rich with a EMR needle and a 42 pilot jet? I'd also untape those airbox holes too and take it for a blast up a hill and see how it pulls. Share this post Link to post Share on other sites
Methotic My Ride Posted October 2, 2019 (edited) 1 hour ago, bumtarder said: So it's too rich with a EMR needle and a 42 pilot jet? I'd also untape those airbox holes too and take it for a blast up a hill and see how it pulls. May have to try that. Btw it's running a 45 pilot. Had it running pretty solid until I taped the holes on the airbox and put the MRD on. Only reason why I taped it to begin with is because when I got the bike the top end was destroyed by sand and dirt that nust have got in through the airbox. Had to replace the cylinder and piston. Edited October 2, 2019 by Methotic Share this post Link to post Share on other sites
bumtarder My Rides (3) Posted October 2, 2019 Just make sure the air filter is new,properly oiled and seated properly in the frame ring with the center washer. Share this post Link to post Share on other sites
Methotic My Ride Posted October 3, 2019 I did some late night tuning last night. I decided to move down on main jet since I've always had a mid to top range bog pulling from low RPM. Went from a 178 to 165 main jet. That helped get rid of most of the saturated bog. The exhaust note is more crisp and responsive now. Also I swapped the 45 pilot for a 42. Seems to idle pretty good now. Although it's probably not the perfect setup, its pretty close. Without a wide band, all carb adjustments are pretty much throwing pasta on the wall and hope it sticks... Currently FCR41mx Main jet: 165 Pilot jet: 42 Fuel screw: 1.5-2 turns out Needle: EMR Leak jet: 35 (might have room for improvement) THOUGHTS?? Share this post Link to post Share on other sites
Methotic My Ride Posted October 4, 2019 Came across a engine part out. Scored on a set of Stage 2 Hotcams. Look to be in good condition. For $130 shipped can't complain! Share this post Link to post Share on other sites
Scottg07 Posted October 4, 2019 1 hour ago, Methotic said: Came across a engine part out. Scored on a set of Stage 2 Hotcams. Look to be in good condition. For $130 shipped can't complain! Good score! 1 Share this post Link to post Share on other sites
Methotic My Ride Posted October 5, 2019 23 hours ago, Scottg07 said: Good score! indeed. I ordered a new Wiseco cam chain as well. Should arrive with the cams on Monday. 12K miles on the bike so could use a replacement. I should probably rebuild the head with Ferrea valves too, although that gets expensive fairly quick. A job for another day I suppose. Share this post Link to post Share on other sites
